I am in the middle of a refurb and I have taken down the plasterboard ceilings in the rooms on the top floor of my house in order to access cabling routes and get rid of an ugly artex problem. I would like to take the opportunity to put some Rockwool in the ceiling before I put up new plasterboard. I have used it in my stud walls and am very impressed with the difference it has made to sound and heat.
I have a flat roof which has a gentle pitch, so whilst the roof joists are deep at the front of the house (24cm), they are only 19cm at the back of the house.
There is no insulation between the joists at the moment. The current insulation sits on top of the joists, but is a 1960’s material made of wood strips and isn’t very effective.
I have read that there should be a ventilated void in the roof, and although there is no sign of any ventilation gaps, I am assuming it is a good idea to leave an air gap. There is no sign of any condensation or damp in there at the moment.
So my question is: If I use 100mm Rockwool leaving a 90-140mm air gap, would that work?
