We have the light fitting shown in the attached in our hall. The bulb has started to flicker so wish to change. Assume it is a 2D bulb.
Cannot work out how to remove the cover.
The translucent cover pushes upwards. Doing so reveals 3 metal tabs that can be seen in the gap at equal spacing around the rim (between the metal frame and the cover - see second photo).
In the plastic cover there is a small 1cm wide notch. Assume this is so you can align the notch with the small cable feeding the green light (emergency light?) on the side when you push up the cover so you don't damage that cable. But maybe its to give access to the metal tabs?
The whole fitting also feels as if it pushes up to the ceiling but on one side only.
Any ideas how to get to the bulb?
