It would be a case of wrong application for the job, addendum: If a back to back switch arrangement has only the live passing between switches as suggested then that would mean two runs either side of the wall running up to lights, this is bad wiring practice you should use feeds and returns between the switches and then run up to the corresponding lights making sure at no point that there are single core runs, use of multicores may have to be used in order for this not to happen.plugwash said:then why the hell is single red and earth made?
where did you find this info?
The cable in question is a modified T&E(Black cut short)
I didn't find this information, It was drummed into me during my training as an electrician years ago.
I have seen the damage that eddys can do in practice.
Don't they teach you about the hazards of running single cables anymore?
