Crikey, it's so rude and aggressive down here amongst the spreadsPeaps your spouting total ball-ocks![]()
I'm back off to the peace, tranquility and gentlemanly behaviour within GD![]()
A realisation of irony would be nice from the self-righteous would be niceWe do get a little bit of niggle now and again- but what do you expect from people who stare at walls all day??????
and i thought everyone reskimmed!
As I type I'm looking at one that was reskimmed 16 years ago.
Still hanging on there.
You need to learn all about plastering then don't you..?
Over skim is an alternative method that doesn't have the self life of a good job. 16 years?!? When I plaster I expect it to be up a lifetime!
Oh you may want to phone Bgypsum and ask about the pros and cons of over skimming using a bonding agent.
Peaps........ your're missing the point again.
For a start, I don't think anyone can learn all about plastering. My dad has been doing it for over 45 years , myself over 25 years and we are learning every day. Anyone who thinks they have learned, or can learn it all k=just displays a lack of understanding of how wide and deep an experience that would require.
When I say I am looking at walls that are done 16 years ago, I am not saying the wall has a 'shelf life' of that time - but that after 16 years it is still perfect under the conditions that presumably will pertain for as long as I live here .
(If I'm spared and am living here in another ten years, then I'd consider 25 years to be good)
I also have been in other buildings that I've overskimmed over 20 years ago and know they are fine. I reckon if something has lasted for 20+ years, we don't need to hold our breath any longer for fear it may fall down. When you get a chance to see your work in 20 years time, I hope you have the same experience.
Phone BG? You are a funny guy, I'll give you that!
Pre Bondit, PVA was standard practice.Ask anyone, even BG who was around then
Now Bond-it is recommended by them for an over skim , or in their words
"High performance plaster bonding agent - specially formulated for use on smooth backgrounds"
"For use on smooth backgrounds e.g. concrete with Thistle Bonding Coat, or for re-skimming."
But as we know, getting your specs right hasn't been your strong suit in the past - maybe you are looking up the wrong PVA again.![]()
Link here
http://www.british-gypsum.com/produ...le_plaster_bonding_agents/thistlebond-it.aspx
i have told mas i wont be posting on here because you will ruin his post like you did the other ops posts i also said if you wanted to put me to the test its only fair i put you to the test which would involve skimming, and just for the record british gypsum recomend their bonding agents for thier plaster i dont think they would recomend it if it had an adverse effect on the plaster like shortening the life of it ipml, you dont reskim?pmsl again,you got a reaction out of me by baiting me and trolling me and taking the p**s out of my bad leg from now on i wont be posting on anything you say about me or any other post for that matter, so say what you want sorry for this mas i wont post any more on here or your post will end up getting locked and ruinedYes and the use of bonding agents is what shortens the life of the skim....
It's lazy to oveskim IMOA. It's also not the same asskimming to plasterboard, the finish reacts different.![]()
So you want to play instead of taking up the offer? Everyone should know your feeble excuse was because you are having a new knee fitted then you went on to challenge me to a skim off, show me how much you can lay on LMFAO all this with a f***k ed up kneee![]()
I did ask for a ref from the pub job, yet another laugh, didn't know who you were
Might just start posting some real truths about stevethecowboy![]()
Oh poor soul. We have already gone through the PVA rant but you still don't get it....
In my world we do a job to last no matter how long we live in the property but your stance speaks volumes to me.
British Gypsum have recomended many ways and products over the years and to the detriment of many old buildings.
But it's all in the method. There are so many things to go wrong when overskimming. Is the PVA correctly mix and applied ( you do know that BG develop their products in a lab enviroment do you not?) What state is the area to be overskimmed ie: is the paint still degrading etc... You applyPVA probably not mixed correctly skim take the cash and run. When The right job to do would be to rip it down, board and skim....
I went to do a ceiling a while back, it had plaster lifting in two areas in the livingroom both above radiators. It was due to the lady of the house drying her washing on them, caused the PVA on the ceiling to fail. When asked when it was skimmed she said it was about 8 years ago....
If a job is worth doing it's worth doing right instead of giving the quick fix alternative inorder to make get the job.
Hang on peaps - it was YOU who suggested ringing BG rather than giving me a reason why PVA/bonding agents don't work, so it's a bit rich disregarding their tech info because it doesn't agree with you
Did I..?
Pva not work, did I..?
Mmmm...
I sugest you keep up I'm sure you are a man who is able to sift through my crap English.
I suggested you ring BG to ask them for advice and data on PVA life and would they recomend reboarding or skimming over with PVA.
Pros and cons lesson in how not to get yourself in a mess by quoting company recomendations of products.
I will drag myself through the rest later
I've cut holes in/ taken down celings and wall with several layers of plaster in them, everything sound - and presumably PVA as the bonding agent.
Examples -
Leak in ceiling, patch needed, whole ceiling skimmed
Lighting change in ceiling, so celing reskimmed
Other Services, ditto.
'Periodic skim' is not really the term - it's done for a reason,as above , not because of time elapsed. Who said the bonding had failed in my examples?
Any thoughts on reskimming a solid wall? Would you go for hacking it all off or a reskim - assuming the substrate was sound but damaged?
I do like to learn through specific information........would be nice if we could stick to the detail
If pva or bonding agent is properly applied as per spec would you still advise taking the ceiling down and reboarding?
