Ceiling reski old board question
24 Apr 2010
Hi all been reading a while finally decided to sign up!
(great forum btw)
Have some artex reskims to do in my parents house but have noticed on one of the ceilings the board appears to have depressed downwards and left visible outlines
The area is directly underneath the downstairs attic so someone may have been a bit careless when stepping around up there at somepoint lol its the only area with this in it though
Shall I proceed anyway (its light artex stipple) or overboard
many thanks!
Hi Gary and welcome to the Forum.
If the area of ceiling you're talking is not too badly damaged, and the pressure on the boards from above has only "popped" the screws/nails,,, get yourself some 2inch plasterboard screws, then pushing upwards onto the sheet, put "plenty of screws" up into the ceiling joists, to pull the sheet back up into place. You are also in a fortunate position, to be able to go up into the attic and put in some extra noggins/screws in the affected area if required. You'll probably need to check out the old tapes to see if they are damaged,, if so,, just re-tape. After that, it's just a case of PVAing the ceiling and skim while still tacky.
In the worst case scenario, and the area is too badly damaged, just cut out the affected sheet/s, and replace them,, tape, then skim "You shouldn't" have to overboard the whole ceiling because of an area of localised damage.
many thanks roughcaster thats great
btw I have read many of your answers whilst reading through old topics and have learnt a lot :)
