    Dismiss Notice
Celotex 50mm or Rockwool 100mm
Discussion in 'Building' started by zug, 22 May 2016.
  1. zug
    zug
    21 Jun 2009
    17
    Thanks Received:
    Country:
    Hello,
    I want to create a sub-room inside my Garage as a small utility room. I may put a PC in there for some office work too. I am planning to build a stud frame dividing the garage into the small room and the remainder of the garage, which will be used for storage.
    I will be using 30mm insulation backed plasterboard for the three walls.
    I am going to use CLS 89mm wood for the frame at 600mm intervals.
    I was planning to use 100mm Rockwool (I'll have to squash it a little bit) but the builders merchants said it would be better to use Celotex 50mm for the walls as it is more much efficient. I know this costs a lot more and it is a little tricky to work with. What is generally recommended?
  2. mointainwalker
    mointainwalker
    24 Aug 2009
    2,438
    Thanks Received:
    239
    Country:
    France
    100 mm of insulating wool (of any type, they have same R values )compressed to 90 mm will give you the same insulation value as 50 mm of Celotex, but have the following advantages.
    a) It will be around 40%-50% cheaper ( for roll type, not batts )
    b) It will give you some sound insulation
  3. Sponsored Links
  4. ^woody^
    ^woody^
    3 Sep 2006
    32,757
    Thanks Received:
    4,428
    West Mids
    Country:
    The advantage of Celotex is that the frame can be thinner and so you don't lose so much space in the new room
  5. zug
    zug
    21 Jun 2009
    17
    Thanks Received:
    Country:
    Well I have already bought the 4x2 and road noise is a concern. I will go with Rockwool. Thanks both!
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
