I have just started my garage conversion on my tandem garage. As i am only converting half of it. I have currently laid a floating floor with dpm,100mm celotex an then 22mm chipboard flooring glued together.Now I am about to build and insulate my walls, i was planning on making stud walls from 4x2 with 100mm celotex inserted inbetween the studs. Heres my questions do i still need a vapour barrier as the celotex is foil backed and acts as a vapour barrier no?? my other dilema is on one wall of the garage is a window inbetween 2 brick piers. The other piers in the garage i was going to box in and insulate with 50mm celotex but i cant do that around the window as the time i put 50mm celotex on the pier and then plasterboard they will overlap the the window any help would be great.
