Loft conversion question ....
The designer has spec'd 3x2 rafters need to be doubled up with 75mm Celotex in-between and 75 under that with PB on top.
Trouble is that the rafters are only 400mm apart so if I double them up I will have gaps of 350mm ( which seems fiddly ) and rafters 4inch wide and 3inch deep... Won't this cause thermal bridging ?
My idea was to instead of sistering the rafters with 3x2 I thought maybe use 2x2 ( will of course check with the SE ) fixed to the underside of the rafter with a thicker ( 125mm celotex between ) and a 25mm with PB under that. The cost is about the same give or take £5 a sheet.
What are your thoughts ?
