- Joined
- 16 Nov 2022
- Messages
- 1
- Reaction score
- 0
- Country
Hi
I've some Celotex 150mm insulation boards left from flat roof insulation project and looking to use in loft floor which has some old insulation in.
Just checking that vapour barrier is still needed and that it is ok to lay as per below image, i.e. up and over the floor joists. The Celotex boards will then just run between the floor joists.
Also the insulation stuffed in the eaves, is this ok to stay or should it be removed as well.
Should add that the loft is just used for light storage.
CHeers
CHeers
