Cement Shelf Life
9 Jan 2011
London
Real rookie question this, Building 101 stuff. I bought a few bags of Mastercrete last summer (2020) to lay some limestone slabs in a section at the back of my garden. Not really load bearing or anything, mainly cosmetic. Anyway, I know cement has a fairly short shelf life, but the bags have been kept under cover and are visually still like new. What could I expect if I attempt to use them? Will they not mix well, not cure well, produce weaker cement? Just wondering if it's possible to get away with using them or if I need fresh bags? Thanks
JohnD
Party? What party?
15 Nov 2005
South
Cook Islands
Is it hard? Or lumpy?
Can you easily break up any lumps with your fingers?
IIRC Mastercrete bags have a plastic moisture resistant layer and are not plain paper. If the bags are unopened they should be fine.
9 Jan 2011
London
No, doesn't seem lumpy, they're still dry. So is it only an issue if the ambient moisture has got to them and they've started to set? That's what I was wondering, because visually they seem fine.
3 Sep 2006
West Mids
If it's powder, you can use it. That includes removing any lumps or lumps that don't return to powder when you squeeze them.
