Then you have gravity HW and the cylinder stat is useless without, plumbing and control (zone valves or mid position valve fitted ) alterations, you will need more kit, could turn out to be quite expensiveFor I only ever had the choice of HW or HW and CH. No CH by its self.
Do not confuse what some call a gravity fed system (proper name is open vent system) with Gravity HW which is what you have , it is possible to fit Nest to Gravity HW but nest dont as far as I know support doing this.Ah ok. Yea. Done a bit more research and seems it is possible with a nest and a gravity fed system. Just to decide now.
Thanks for all the help
Just put in two port valveWhen binding the HW kit to the evohome, the instruction as what type of valve I have. None is not an option.
It is not possible to use evohome without a valve. (I checked with support also)
