Central heating boiler
30 Nov 2006
Staffordshire
Hi
Not switching on, it was working fine until i tied the central heating side, (Rads) it has a manual gate valve to open this side up, tried to bleed air out but i think, i now have air in the boiler.
Just started to work on it when visitors arrived, so i think i turned vale off above the pump by mistake cutting water off to boiler when it was still running. (Not sure)
Anyway boiler will not start now. Think it closed down it self. Fan does not run, wil not spark up, have checked the fuse on motherboard it is ok.
It is an old boiler and has worked well over 15 years blue fuse once many years ago repaired and fine until now more or less.
Please help Stuart
Sorry
Glow worm fuelsaver f
Tried to put in basic details and miss the important bit.
Is there a reset button on this model
Thanks for reply Stuart
found it under neath working now
Thanks Stuart
