Well i will probably flush it through once a year. However the main reason is its a 3 floor flat and will be easier than running a hose down the stairs and i have the chance to do it now as i am doing lots of other work in the flat.
Because every time you refill it you will add a fresh load of water to add another layer of limesfale, and dissolved air that will set up another round of corrosion, and will have to pay for another supply of chemicals.
