Hi all
Have had some great advice on here so far and I'm hoping someone will be able to give me some guidance or even offer to come and fix (paid of course)
I have a rayburn nouvelle, gas, that is pumped central heating and gravity fed hot water (I think)
I woke up to a cold house last Saturday - I changed the fuse in the power socket and it sprung into live for 5 mins. I changed the fuse again and it lived for about 6 hours before going off.
I decided to change the pump, so spent sunday struggling with that. However new pump is on and working but I still have the same problem. I'm nearly 100% sure that it isn't the pump causing the problem as I've run that off a plugged socket separately for a few minutes and it didn't blow a 3amp fuse that was fitting on the plug.
So what else could be wrong that is causing a 13amp fuse to blow? I know it should be 3amp now but 13amp was what was in the socket and before I read a few posts on here I didn't know any better.
I've opened up the timer unit and no sign of burnt wires.
I called a central heating engineer out but he said I needed an electrican - but I don't think an electrician will want to look at the gas boiler ?
Can anyone suggest a man or woman that would relish this kind of challenge? Changing the pump was challenging enough!
Many Thanks
Many Thanks
