Hi
I have a cold downstairs radiator.
I have recently had a towel rail fitted which was connected via 15mm polyplum to a T peice polyplum to a 22mm feed and return copper central heating pipes.
The 22mm pipe feeds the newly installed towl rail then a radiator in the bedroom then it dropps to 15mm and runs down the wall to the cold ratiaor downstairs.
The towl rail is hot, the bedroom is hot, the pipe starts to cool and is cold to the touch befor it dropps down the wall to the radiator.
So, im confused?!
It must pass through the newly installed T peice becuase it heats the bedroom radiator but stopps near the reduction from 22mm to 15mm?! Could it be blocked?
Have run sludge remover through system for 2 weeks.
Thanks for any advice
So, im confused?!
