Central heating not working on Timer mode
29 Oct 2004
Hi
I seem to have an issue with the timer on my central heating system.
We moved into new house a few weeks ago, I checked the boiler, and checked the heating/hot water - all seemed fine.
Some of the upstairs rads were a little cool, so bled them - lots of air - all seemed fine.
Until yesterday - The hot water works 100% - either manually turning it on, or from the timer.
The central heating however, will not turn itself on from the timer - I can do it manually (like i did at 5:50 this morning!) but from the timer it;
Fires the pilot light
Makes a few quite loud (loud enough to wake me up) banging noises
Goes back into standby
Repeats every 5 minutes or so
I'm presuming therefore that it's an issue with the Timer?? Any ideas
Please help - I don't want to have to wake up early again
It's a Suprima L boiler. Timer is an electronic one - not sure of the model
an update
left the CH on all night - dropped the temp to 16 so it wouldn't be too hot/cold
problem - woke up - felt cold :cry: - rads not warm
Checked boiler - it had locked out, pressed reset, CH back on again
Still the same with the timer obviously
What's going on?
It's a drayton tempus seven
can't see any model numbers
Hope this helps
thanks
first guess is that your ch valve doesn't open, or blockage/airlock in the heating pipework.
would that stop the CH working completely?
how can I check for airblocks in the pipework?
Airlock. I normally listen to the sound, and try to find obvious places to bleed, but would have a hard time explaining how you do that over the net.
airlocks in the pipes - how do you bleed those?
would that be on the FAQ?
i've bled the Rads.
Why would an airlock stop the boiler coming on during 'auto', but not during 'constant'?
