Hi Guys,
I just finished installing my own D.I.Y central heating radiator system and it does not work! Had a Wochester Bosch 24i GreenStar Junior installed 10 months ago after the old boiler packed up 2 days after moving in to the property. The Gorgi Engineer that installed the boiler put a loop on the heating system as there were no radiators in the property and it was using storage heaters at the time which have since been removed. I installed my own rads and pipe work in a feed and return system with an automatic bypass between the feed and return currently set to maximum (7bar). All is hooked up to the boiler and filled they system up with the built in filling loop filled the system up to 2 bar maximum it would go up to. Turned the boiler back on and turned the central heating on an nothing happens hot water works fine! Any ideas what I may have done wrong?
PS: I did get the heating to work when I pushed down the button on the boiler with a spanner on it seems to put it is a maintenance Service mode not sure but it works and all rads heat up etc but after about 10 minutes it goes out of service/maintenance mode and heating stops working! I have read the manual and cannot see anything specific that may be wrong!
Any help/advice would be greatly appreciated….
Cheers
Cheers
