That sound OK,though the vertical extension to the overflow is odd, unless it has a mesh or similar inside to prevent bugs entering.I did not explain myself too well on that post.The overflow has a connection to it inside the tank which is about 4" long and points vertically down. I presume it is fitted to stop bugs/insects getting into the tank. The water level is 4" above the cold feed outlet. I hope that makes sense and many thanks for taking the time to dig through the history
Have you ever had your system balanced? If so, what was the procedure followed?
As all radiators get hot very quickly it is something I have not tried
