My boiler is an IDEAL CLASSIC FF370 and is in the garage. I have two water tanks in the loft (one small, one karge) and the hot water cylinder in a cupboard on my landing.
The hot water is working fine. I have not had my heating on since around April so have not noticed any problems before now. It was working fine the last time it was used.
My problem appears to be that the pilot light is not lit! I have followed the instructions inside the boiler door and it does not re-light.
The `overheat thermostat re-set button' does not seem to be a button!!! it looks like a brown plasic grub screw screwed into a small falt brass nut and does not press in?? Am i looking at the wrong thing?
Is that the re-set button and how on earth do you `press it in' ?
I can hear a humming noise (pretty quiet) which i assume is the fan - so that seems to be working.
I have bled the pump - however, when i open the screw the water only dribbles out and does not pour out which i would have expected if the pump was working properly??
The actuator has three positions H,W and M and appears to be stuck on H although yesterday evening it was on M?? (it is labelled the mid point actuator and is located on a tee - the branch of which goes to the inlet on the pump. Historically this actuator has made some peculiar noises and was quite loud.
I recently had one of the bathrooms tiled and the plumber removed the toilet and sink. The sink had no isolating valves so the water supply to my property was off for a while - could this have caused the problem??
Any ideas as to what i should be checking or looking at before i `get a man in'
Any help would be appreciated.
The whole system is only 6 years old.
