I had a replacement boiler last year (worcester 15ri) and just started using it,
there's tapping noises and banging pipes etc so i have got some fernox F2 to try and improve it.
i have also noticed i'm having to bleed one rad often and looks like air's getting in , so i have tightened all rad connections,
i did have a leak on the gatevalve heating the emersion tank just after the 3 way valve which i repaired using ptfe tape.
i'm just about to flush system and add some F1 and F2 but should i replace that gate valve or maybe just put straight pipe in ?
what's that gate valve for ? should i be reducing the flow of central heating water through the emersion tank ? or is it always left fully open ?
in the summer i also replaced the pump (had wilo smart pump and replaced with grundfos alpha 2L).
because the upstairs is noisy i have been closing off the bedroom rads but the boiler seems to be struggling , i set the pump to max to try and get the downstairs hotter but seems to draw more air in and make more noises somewhere.
so i have set the pump to fixed 2 which seems the best.
i've also been adjusting the boiler temp. and just under half way seems ok ?
i went up into the loft to see if any pipes were touching or rubbing each other and i noticed that two times water splurted out the expansion tank vent (i did set the boiler to over half way so maybe that caused it ?)
please any advice welcome i'm going round in circles trying to improve it,
house is 2 storey early 1980's seems to be standard open vent heating system .
i also had trv's fitted at same time as boiler.
downstairs everything is working well.
sorry about all this info. i'm basically wondering if i can remove that gate valve or do i need it to reduce flow through the emersion tank , also any other tips appreciated.
thanks for looking, chris
