I've recently moved into a new property and i have an issue with the central heating/hot water in that i cannot get the programmer to switch both on at the same time!
The boiler is a British Gas 330+, the programmer is (based on a warranty sticker) 1997 Danfoss.
When for example the hot water is called via 'auto', or set manually to 'on', i am then unable to also turn the central heating on, the LED just flashes on then back off again. If both are set to 'auto' when the time comes around the LED's will flick between c/h and h/w probably until it burns itself out.
Based on your experiences is this likely to be an issue with the programmer or the wiring? I can't imagine that the previous occupier would have been able to live with this for the last 3 years (i'm assuming if its a wiring issue its been since british gas installed that boiler in 2011).
I can switch out the programmer obviously at a cost, i just want to get a few opinions in case i can debug it another way!
Regards,
Shaun
Regards,
Shaun
