Central Heating pump
Thanks for the link. Am going around this morning to get rid of X years of accumulated dust so that I have a better view of what is what.
I see that a head unit is available, so perhaps it will not be necessary to remove the two 1 1/2" nuts. Your link also shows the isolation valve in more detail which is useful. Pretty much what I can already see.
classic plumber line trying to condemn a bulletproof kingfisher boiler mate, don't let them mug you off for a full swap if the cast iron heat exchanger is fine. for those 30 year old 1 1/2 inch pump nuts, soak them in plusgas for an hour then get a blowtorch on the iron nut while holding the pipe with a decent footprint wrench so you don't twist the copper. if they're completely fused, the proper trick is just buying a grundfos ups3 or similar pump head, unbolting the 4 allen bolts on the pump face, and leaving the existing iron pump body in the pipework so you don't even have to crack the unions.
This forum really shines when you get replies from folk who are still on the tools. Thank you.
Removed the side panel this afternoon and access to the pump connections is not a big deal. I would try the central screw thing but the pump is kinda beside/behind the boiler/ wall and access from the top is restricted by the flue and some piping, so cannot actually 'see' the screw unless using a mirror. Removing it would be a touchy-feely task with no direct view and a risk of dropping the screw cap.
The current pump is a Grunfos 15-50 x 18 which is listed a discontinued but does have an anticlockwise rotation arrow.
Checking the internet, replacement Grunfos are not the cheapest but perhaps that is the way to go. Other brands are around half price; Strada (https://www.mpmoran.co.uk/strada-pr...tic-heating-circulating-pump-230v-109142218); Parker (https://www.parkerbrand.co.uk/circulator-pump-pcp-156-130/) etc. Are alternatives all much of a muchness?
Most that come up from an internet search have a clock wise rotation; presumably I need anti-clock, as the current, non-working one?
Seems reasonable to head for a full replacement. Has anyone actually confirmed the power is going to the pump on a heating call?
Wilo used to make a pump that was a straight swap for your pump and a lot cheaper.
