Hello,
Some time ago I had a problem with my motorised valve and duely called out the engineers that my central heating insurance company use.
After they spend many days trying to sourcer another valve and after finding one spent ages wiring it in, I'm still left with problems.
Since then I have had serval visits from another company who my insurance company now use as the original one is now not on their approved list.
The second companys engineer decided to change all the control equipment as he said it wasn't compatable. He changed the motorised valve, timer unit, room thermostat and the wiring junction box.
The system still doesn't work properly and now they say I need an electrican out, which my insurance does not cover, to sort the wiring out.
The fault is :
The heating will come on using the room thermostat even though the heating is turned off at the timer.
The hot water will not come on unless the heating is turned on at the timer and the room thermostat is turned up above the current room temperature.
The heating will not come on if it is turned on at the timer regardless of setting on the room thermostat.
It sure looks like a wiring issue but considering I never had this problem until the first company changed the motorised valve, i don't see why I should have to pay to get it fixed.
Could anyone point me to what may have been cross wired so I could attempt to resolve this myself
Thanks for any guidence.
Phil.
The fault is :
Phil.
