Hi, if I have some timber (150mm x 47mm x 3 meters long), and I intend to fix it between two 75mmx75mm posts. Will I need to install a centre post? This is basically the open end of a lean to that I intend to build.
Thanks for the reply foxhole.
Maybe my quick (not to scale!) sketch will help clarify.
I also have no idea whether brackets are availble to fix all this together i.e. like some form of joist hangers or something, or just screw the wood together.
I'm also not sure at the open end which way is best to fix the rails so that they over hang - probably do a a heal / seat cut from what I have read.
