Hi chaps.
I have raced through as many of the similar threads and cant find a solution that works.
Only the kitchen tap has a much reduced flow. All other HW taps running clear and well. Have backfilled - turning hot and cold on together whilst keeping my thumb over the mixer - for 15 secs - immediate effect but dribbles to muddy water in 3 secs and then clear water but v v reduced flow.
New (9 months old) gas boiler and cylinder. Cylinder and boiler at ground level. Tanks (main and header?) in loft. The latter are working - filling and ball valves all OK.
There is a drain valve at the base of the cylinder but I'd like to be clear what else I can do to trace and find the fault and suggestions on how then to immediately cure it.
Good Friday and all. And people visiting. Bit of a mare.
Any help appreciated.
bcm
bcm
