First of all I will say hi and thanks for any help or advice. I seem to have a common problem. I am no CH expert but I am a qualified aircraft engineer, so I can work things out fairly well. If not, I will pass this on to someone more qualified.
My CH will not come on. The timer is a Danfoss fp715 and the light is on. If I turn up the thermostat, a Danfoss RMT230, it clicks but the boiler will not light. My system is a Vokera Mynute 20e combi boiler with a hot water tank.
I removed the cover from the thermostat and I was presented with 3 wires connected to it. Red, Blue and yellow. Assuming blue is neutral, I get 240v from red and nothing from the yellow. When I turn the dial down past 18 degrees I get 240v from the yellow.
I assuming the thermostat is faulty but I am having no luck in finding a suitable fault finding guide.
Any help will be appreciated.
Jamie
Jamie
