Hi
My CH system has an issue. The HWC is taking long time to heat over 2 hours, used to take an hour before. Same applies to the heating. There were grinding noises in the airing cupboard one day last week. I started looking last night, the two divertors valves are working fine, I bled the 2 AAVs and rads. The boiler is firing but only stays on for 20 sec or so then a long while 30mins or so to fire again, there was quiet grinding noise in the airing cupboard; assume from the Grundfos pump which was extremely hot to touch. I tapped the pump but no change.
I think the pump is at fault??
Any tests to do?
Photos attached, Is turning the big slotted screw would help?
Any tests to do?
