change of use Live/work to full residential
27 Nov 2012
London
I have a small warehouse in islington which has live/work usage . I wish to do alterations to it , extension or basement . In order to possibly do it under " permitted development "( maybe building regs issues too ) I understand that it has to be a full residential unit . I believe that there is quite an easy way of changing this over with new legislations etc but cannot find out how. Does anyone know? Also the property is within a conservation area ( in Islington ) . Think this could also be an issue?
Warehouses do not have permitted development rights. You'll need to apply for planning permission.
Thanks for the reply. Are you sure , even if the building has full residential?
The government changed the rules to allow retail to residential changes under PD, and that was what I was thinking about. But it seems that the rules were then changed again to allow the same thing with warehouses. :oops:
It's done under the "prior approval" regime, whereby the council can assess the proposal and may require a full application instead. But being in a conservation area may require a full application anyway.
Conservation Area or not, I'm pretty sure Islington "Article 4'd" the whole Prior Notification thing, so check with them, but I think you will need a Planning Application.
