We just moved house and have changed the light fightings in the hallway. Its a 1930s house and there were some horrible lights in here from the previous owner.
Upstairs hallway had a ceiling rose (1 bulb) with 5 wires, and it seemed easier as per the instructions that came with our new fitting to attach it to the existing wiring already installed since it had instructions for connecting it in this manner, but none for what to do with the 5 wires if I wanted to connect them to the kit that came with it.
We've also done the downstairs hallway light which had a brass fitting (1 bulb) and that was simpler - 3wires as normal to plug into the new lighting fixtures kit.
Fitted 3 new energy saving bulbs (7w each, each light says maximum, 9w cfl) to each of the new fixtures and turned the power back on again and turned the lights on. They both work fine, but when I listened carefully by the switch I could hear a "fizzing" behind the downstairs switch.
Downstairs the switch controls the downstairs light, upstairs light and the light outside at the front of the house. The upstairs switch only controls upstairs. There's no fizzing nois from the switch upstairs, or from the downstairs switch when I turn on the upstairs light, just when I turn on the downstairs switch for the downstairs light.
Is likely to be just a loose connection in the fitting downstairs, and all I need to do is re-check the connections, or is it something more severe?
I've checked behind the switch and everything seems to be fine there, no loose connections.
[/b]
[/b]
