Changing a cooker socket to standard 2 gang, but not RCD protected. Allowable?
2 Dec 2004
Lincolnshire
The wife wants me to add some sockets where she works, but one of them involves removing a cooker outlet and swapping over the switched socket to standard 2 gang socket outlet. The problem is that it's on an old Wylex fuse wire board and although I could swap the red 30A fuse to a blue 15A and even run it off an FCU, it's not RCD protected. Is this allowable?
No.
Odd that someone competent to do electrical work in a place where the Electricity At Work Regulations doesn't know that....
And what's the fuse rating got to do with it?
Bear with me as I'm still doing my Level 2 at the moment and I'm getting my ears bent by the wife to help.
Thanks for pointing that out. I did wonder how I was going to RCD protect any alterations, hence my OP (needed clarity from the experts).
I could use a double in place of the cooker switch and a single RCD FCU to move one of the other sockets which is on a different circuit.
Yeah, but.
Yeah, but.
Yeah, but.
There are no exemptions in the EAWR for people having their ears bent.
Which is why I asked for confirmation first as it's better to check in advance rather than blindly crack on without the relevant info.
Helpful comment though...
