- Joined
- 19 Aug 2021
- Messages
- 11
- Reaction score
- 0
- Country
I’m planning on replacing a towel radiator (like for like size) and had a few questions I’m hoping someone could help me out with.
I plan to isolate the rad at the valves at the base of the rad, drain it into a bucket (using the bleed valve to release all the water), install and connect the new rad and turn the water back on (closing then bleed valve when water starts to come out the top). Is that correct? Do I need to worry about the central heating pressure or do anything with the megaflo tank?
It seems simple but I don’t want to make a mistake which then leads to a problem. I’ve made sure the new radiator has the same pipe centre measurement.
Thanks in advance for any help.
Matt
Matt
