Changing aPIR on a burgu;lar alram system
19 Jul 2010
Cambridgeshire
My alarm pad was showing the hall as the culprit for my alarm going off.
I purcahsed a honeywell with 8 terminals. Do I miss out the first and fifth terminal from the left as the original only had 6 teminals?Also the original fitter used filler to secure the PIR as he had made a large hole behind, which I had to fill. My alarm went off as I was waiting for the filler to dry (with no PIR wired up in the hall) was this why my alarm went off and I could not turn it off for quite some time? OR am I doing something wrong?
Any other tips would be most welcome.
What type of honeywell detector, there are a few?
What type of wireing method is your system employing - EOL or Double pole?
Do NOT use anything wet to seal cable entry holes in the back, blue-tack is more acceptable.
THANKS FOR YOUR REPLY
The Honeywell detector is a Activ8 PIR Single Channel Quad Element PIR.
Not sure of wiring system, how would I check?
Have a look in one of the other PIRs what colours are used and post them here. Would have been wise to make a note before you took it down!
As for the alarm going off, it's possible that the power wires accidentally shorted together, blowing the fuse and causing the bell to sound from its own battery. Are the existing PIRs lighting up still?
