Changing bath waste
28 Jun 2021
Hi
Bath waste needs to be changed. 2 Photos of bath attached. Will the bath waste and over flow in third picture fit?
Waste hole size on bath?
To answer. Should do. Size up.
It is standard size
It;s a rental flat, plumber went tenants there, took the waste apart where it was leaking told them old part will go and if he can find replacement, luckily I called the tenant an hour later told me the story and sent the bath pictures, then I took that third pic from screwfix sent it to the plumber and he said yes that will fit BUT he calimed he is 20 miles away from property in Staines heading to a plumbing merchant. There is SF, B&Q, Wickes, plumbers merchants within 2-5 miles of the property, it's in UB6 London. Cut the story short, he conned me charged for 4 hours labour when it was one hour job. Once they hear you're landlord they want to rip you off, some traders are scumbags. I couldn't not pay him because there are tenenats there and can't disconvenience them.
Idiot.
If you didn't want to pay a tradesman then you should've done it yourself.
The time spent on the job is irrelevant. If he's doing your job, inc his travel time to/from etc not to mention his training and experience etc then he is not working elsewhere.
Are you one of those rogue Landlords that the press talk about??
An idiot thrown to the ignore list.
To defend such, must be doing same to LLs.
It is upsetting to be accused of rogue landlord by a stranger doesn't know me on a forum and also to be called names.
Tenants repoerted the leak on Tuesday 6.20pm, the leak was repaired Wednesday 4.00pm. In less than 24 hours.
There is only one idiot here in this thread and we all know who he is. He should look in the mirror. He is a rogue trader as per his reactions. He is also a troller. Thanks for having ignore list in this forum.
