We had a brief power cut here at the weekend. I was surprised to receive an immediate "12v fail" alert which stayed until I could reset it after the power was restored.
We actually had a longer power cut, about three hours, just before Christmas, and there was no alert then. So if the battery has failed it is rather sudden.
Looking back I find the battery is four years old, so it seems a reasonable conclusion that it needs replacing. I will be collecting a new battery tomorrow.
According to Wintex, the battery voltage is the same as the power supply voltage at 13.46 volts and the supply current is about 0.5A. It doesn't show any fuse failures.
Does this sound like a simple battery failure to you experts, or could it be something more serious?
Am I right in thinking that in engineer's mode I can remove the old battery and connect the new one without any other settings or precautions? Providing the mains is still on I assume there will be no alarms to annoy the neighbours..
Any advice gratefully received!
