- Joined
- 28 Jul 2004
- Messages
- 19
- Reaction score
- 0
- Country
I posted a while ago regarding my dodgy old wylex metal enlosure CU here [url]//www.diynot.com/forums/viewtopic.php?t=12138 [/url]
I am now finally about to change it but the REC arent willing to move my incomer. This means I only have 240mm between the wall and the side of the incomer. I cant move down or up with the CU because the 6mm t+e will not budge in the conduit and I dont have the money for a full rewire.
I intended on buying a spit load metal enclosdure cu from MK but the narrowest one is about 380mm wide. Too wide.
Could i fit a standard CU (ie not split load) and still have a safe installation? the k5508 from MK will fit snugly.
What do you guys recommend?
Can I still earth the enclosure as you see in the previous post, but replace the galv strap with 16mm earth cable?[/url]
