If i wanted to change my Alarm Panel (self installed) from a G2-12 to G2-48 panel, whats the easiest way to move the bell box connections with making the least amount of noise?
I'm assuming that as soon as i remove the current cable connections from the board, the sounder is going to sound until it gets power back from the new panel?
The sounder is a Pyronix deltabell which i believe has an engineer hold off but does that help with when power is removed or is that only for if i was replacing the bell box so i don't get deafened when opening it up to remove the connections when the panel is in engineer mode.
