    Dismiss Notice
Changing door handle ?
Discussion in 'General DIY' started by swayzak, 6 Oct 2013.
  1. swayzak
    swayzak
    1 May 2008
    96
    Thanks Received:
    Leicestershire
    Country:
    Sorry - really basic question.
    How do I remove & replace this door handle ?
    [​IMG]
  2. Sponsored Links
  3. Burnerman
    Burnerman
    7 Feb 2008
    23,146
    Thanks Received:
    4,500
    Northumberland
    Country:
    Undo the 4 screws, and the knob pulls away from the door.
    It may, or may not pull the square follower bar with it. The follower bar can be threaded or grub screwed in place - sometimes on the knob that remains on the other side of the door.
    John :)
  4. noseall
    noseall
    2 Feb 2006
    43,466
    Thanks Received:
    2,685
    Staffordshire
    Country:
    The obvious thing is to remove the visible screws.
    The spindle may be held into place via a grub screw which will need undoing on at least one of the knobs.
    Are you replacing knobs for (lever) handles?
  5. swayzak
    swayzak
    1 May 2008
    96
    Thanks Received:
    Leicestershire
    Country:
    No, happy just to replace like with like (rest of handles are round).
  6. noseall
    noseall
    2 Feb 2006
    43,466
    Thanks Received:
    2,685
    Staffordshire
    Country:
    We call the round ones knobs. :mrgreen:
  7. Sponsored Links
  8. mattylad
    mattylad
    27 Apr 2008
    8,285
    Thanks Received:
    632
    Country:
    If your putting like for like there then why replace it?
    Take it off, polish is well and if needed recoat with laqcuer.
    Replace the screws so that you only need 1 screwdriver to remove it not 2, either all cross head or all slot :)
  9. swayzak
    swayzak
    1 May 2008
    96
    Thanks Received:
    Leicestershire
    Country:
    Thanks again
    The reason it needs fixing is that it is really stiff to turn, and doesn't pull the latch completely in - makes opening it very difficult.
    I'm concerned soon I won't be able to open the door at all once it's been closed.
    Will just lubricating cure this or do I need to replace the whole unit (including latch part) ?
  10. foxhole
    foxhole
    14 Mar 2006
    17,993
    Thanks Received:
    2,064
    Kent
    Country:
    Fault is more likely the catch being worn out , knobs have no working parts to fail.
  11. JohnD
    JohnD
    15 Nov 2005
    74,232
    Thanks Received:
    4,289
    Crossgates, Europe
    Country:
    Cook Islands
    Once you take the knobs off, look to see if the spindle is binding n the holes in the door. It looks like an old knob fitted to a new door. The springs in the old knobs may have broken.
    If not, the mortice latch might be worn. You can buy a new Tubular Mortice Latch very cheaply. the old one will pull out, you can loosen it by tapping on the spindle. Measure the old one very carefully, different makes vary slightly in length. If you can get the same make as before it will be a bit easier.
  12. noseall
    noseall
    2 Feb 2006
    43,466
    Thanks Received:
    2,685
    Staffordshire
    Country:
    Knobs, as opposed to handles require the deeper tubular latch. This is so that your knuckles clear the rebate when twisting a knob.
    Handles = 64mm deep latch.
    Knobs = 79mm latch.
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
