Doing some maintenance on my heating system.
System boiler>copper tank>F+E tank in loft> Honeywell Y plan>7 rads.
Changing out the old UPS pump for a newer UPS3 (and new pump valves)
Also fitting a Tado V3+ thermostat.
(Would also like to fit a Spirotech MB3 somewhere in the system, can't get it anywhere near the boiler) so would probably have to fit amongst this lot, just before or after the pump)
X400 system cleaner has been in for a couple of weeks.
Whilst system is drained down, I'd like to replace the 3-port valve with a pair of 2-port valves, and leave an extra blanked off Tee for future UFH in an extension.
What's the best way to achieve this with the current set up?
Are there any 'rules of thumb' that need to be followed when Teeing off or adding valves?
Looking at the 3 port valve, the left hand port goes to water, the right goes to rads.
Space on the heating side for a 2 port valve, but the HW side the pipe immediately turns upwards, then a kink in the pipe brings it back in away from the wall.
