changing old fuse wired consumer box to rcd/mcb consumer box
28 May 2004
Hi all,
I am thinking of upgrading my old consumer (fuse wired) box for a new rcd/mcb type.
Could someone pleas give me a rough estimate as to what this would cost if done by qualified electrician.
thanks
tc
My old fuse box has six fuses in it, 2xred 2xblue & 2xwhite. Is this the info you need :? ?.
tc
tc
Do you have a TT, TN-S or TN-C-S supply?
What size is your main bonding?
What state is your equipotential bonding in?
Does your lighting circuit have an earth?
How old is your existing wiring?
Do you have sockets that could reasonably be expected to supply outdoors?
Do you have any expansion plans, like electric showers, electric cooker?
I could probably come up with more questions given more than 30s.
It's not like changing a light switch, and unexpected things can arise, e.g. if you don't have an RCD right now, and you fit one, previously undetected faults might cause it to trip. You need to get people in to have a look and poke about and give you a quote.
thanks for the reply ban-all-sheds,
oh dear, i only wanted to change my consumer unit. Didn't realise how much was involved.
how would i find this out ?
what's bonding ?
I know when i fitted a celling fan in the living room there was an earth wire to attach.
Not sure about this one, i have been in the house for 6 years.
No this is why i want to upgrade the consumer unit, to have RCD protection, to have a small consumer unit off the new consumer unit to my shed.
There is already a shower fitted to the old consumer unit, looks a bit cowboy to me.
diyfanatic
as you said (and have now found out) there is more to it than just chnging a box.
best get an electrician in to do it for you.
but do get several quotes
Rough method of telling age of cable - is it stranded on lighting or power?
Indeed.
So you need to decide how long you want to leave the job - should you get it done now by an electrician, or leave it until you've learnt about what's involved?
Hi all,
As much as would love to fit the new consumer unit,I definately wont be fitting it, there are M.E.B seals to where the mains comes in so i'm not gonna tamper there. I really was just wondering wether a new unit or convert old fuses to mcb's. But of course the latter way i would not have RCD protection for outdoors electrics.Hence my question for rough quote.
diyfanatic
That's interesting, how would the Electrician isolate the supply when changing consumer units?
they just break the seals and pully the bloody service fuse
apparenly you have to be carefull on older serivce fuses because pulling the fuse can expose live parts in the holder
it does, also an electrician will carry out an "insulation resistance test" (amongest alll the other tests) first. this is part of the reason it is NOT reomended the diy person changes their consumers unit
install new sockets, lights cables yes, consumers unit, NO
