Changing the look of the external render
wig
14 Jun 2006
PONTYPRIDD
My house is rendered outside with dark grey chippings. It looks kinda dark and depressing.
Would it be ok if I brushed off all the chippings and painted it white?
Also I noticed there is a crack running up vertical in part of the render, it is about 1mm wide. Should I use some sort of dremmel thin grinding tip to gouge the crack bigger and then fill it in? What do I fill it with?
itll look bad.
exterior filler, or fill it with paint as you go.
