I want to fit a new toilet cistern, but the inlet water supply pipework needs to be altered. The issue i've got is that the house hot water is fed from a tank and last time i changed the kitchen taps i had to drain the system and when i re-instated the water had issues with no pressure, this was solved by a plumber friend.
If i isolate the main incoming water supply, i hope as there is no hot water involved, there will be no issues as before. Will this be the case?
