Cheap, small glue?
19 Apr 2015
Aberdeen
Hi, all,
I need to glue a screw in to a wall, just the one screw, so need a strong, cheap, small tube of glue. Can anyone recommend? Thanks.
Aye, a rawlplug mate, if the wall is brick or otherwise solid.......for plasterboard, look up 'cavity wall fixings'.
Can you be more specific, please?
John :)
You can get epoxy adhesive at the pound shop.
Thanks, both.
John, it's four screws to hang up a towel rack. The other three screws are firmly in, all three have a washer? and one of the ''washers'' says rawl on it. It's just this one screw that is loose, although I believe it has a rawlplug on it. The wall isn't brick, and seems fairly soft. I just thought I could fill the hole with glue and shove this final screw in, and let it set, instead of getting a rawlplug?
Thanks.
From your description, it sounds like you have drilled into a soft wall surface, maybe plaster or thermalite block. Maybe the plug in the wall has come loose, and is spinning when you try to tighten the screw.
The usual repair is to glue the plug in place (no nails adhesive is good) or re drill using a larger diameter plug with a bigger screw.
It's best to remove the towel rail just to see what you are dealing with!
John :)
Nonails from poundland.
Cheap & nasty but good & cheap enough for 1 screw.
Thanks, both.
I didn't drill anything, it was just like that when I moved in. The towel rack is firmly removed at present! I'll get the glue.
