also 2.5 mm² and is flexible plus has plug and socket. That's if you need 2.5 mm² since most 13A leads don't need to be 2.5 mm² most will as ready made have thinner cable.
In which case why 2.5 mm² if using a 13A outlet 1.5 mm² would be ample. Also easier to get 1.5 mm² in a plug. I am assuming there is a reason behind using 2.5 mm² cable?
