- Joined
- 5 Sep 2016
- Messages
- 67
- Reaction score
- 2
- Country
Hi folks
Firstly, I'd like to make it clear that I'm not looking for a cheap and nasty way of fixing my ceiling. I'm happy to spend money but would like to pick the brains of folks who are more knowledgeable of alternative methods that might be available.
I am replacing a lounge ceiling in an old stone walled terraced house. The existing ceiling looks and feels sound but it slopes badly from one side of the room to other which looks terrible. The ceiling is approximately 150mm to 200mm lower on one side of the room (side to side), joists run from front to back.
I want to remove the existing plasterboard and replace with new plasterboard utilising the cheapest method possible to level the supporting structure. I am extremely cost concious (materials), extra labour is abundantly available at no cost (me!).
I've done some basic research on metal furling ceilings etc. as these are supposed to be cheaper than timber but this seems to be based on the drastically reduced labour required to install them. I'd like to keep as much ceiling height as possible so have considered fixing the supporting structure to the sides of the existing joists with no overlap on the lowest joist and largest overlap on the highest joist. The thickness of the new supports will obviously need to be thick enough to allow for abutting two plasterboards together with enough width to take the associated screws. The only way I can think of achieving the required thickness is to buy the cheapest 8'x4' timber sheets available, rip them down to 200mm strips, fix to sides of joists, then rip thinner strips off the sheets and fix to the bottom of the 200mm strips to achieve the required thickness for plasterboard screws.
This sounds laborious (well, because it is, and I'm fine with that), but is it technically sensible? Could I please have some suggestions on potential dirt cheap methods of achieving this by any means? Any comments gratefully received!
ATB
kingofthehill
ATB
kingofthehill
