When i had a loft conversion done a disused flue was capped. This has led to condensation. The brick stack runs down the side of the house. The condensation has resulted in a large damp area 2m x 2m around the bottom half of the stack. Internally i have noticed tarry deposits coming through the plaster
If i put some air bricks at the top of the stack to restore ventilation will this cure the condensation issue. Also will the brickwork dry out in due course (or does this need to be repaired)
[/b]
[/b]
