Chimney in kitchen.. what to do with it?
  • Thread starter Thread starter Deleted member 281264
  • Start date Start date
D
So I want to run a long run of kitchen cabinets along the wall where the chimney is and a metre or so into the new extended area but not sure how to tackle it
As you can see in the plan there is the chimney breast and then where old meets new cavity wall there is a slight protrusion and I want the kitchen running along all of these different points
Of course I could remove the chimney but that is messy and costly and there is only 10cm of difference between the chimney breast and the new cavity wall. I don't want to build a kitchen around the chimney breast either and fit a cooker inside but rather hide the chimney breast
Any suggestions much appreciated:D
Fill in the difference. Put in stud wall with sound insulation to next door.
As putting up cabinets consider where they will be hanging from and ensure there is wood in stud wall where you will put their screws into.
That's something we tend to a lot of in kitchen zones...
I would probably fill in the one near the corner, then make use of the one on the extension end (with a deeper worktop) to sit toaster / coffee machine / etc. As the extension protrusion is not the same as the chimney it will look odd if you infill it IMO
Why not just open up the front of the chimney breast to ceiling and push the cooker back into it? That's quite common to do and the stub walls either side of the cooker just form the ends of a run of cupboards.
