- Joined
- 29 Mar 2023
- Messages
- 42
- Reaction score
- 0
- Country
Hi all,
We are removing our chimney breast and are down to the floor of the 1st floor bedroom. The floor joists for the bedroom rest on the chimney breast below which is 1 block bigger for the joists to rest on. The joists run from the back exterior wall to the top of the chimney breast (about 250mm from the dividing wall).
The gap we need to fill is approximately 250mm in length and across 3 or 4 joists at 400mm centers. The joists are an actual measurement of 7inches x 3inches.
The dividing wall is a single skin, engineering brick wall, 100mm thick.
The structural engineer said the breast wasn't structural and could be removed brick by brick, top to bottom and the floor fixed with either a ledger board or wall pockets.
If we go for a ledger board, would we fit a 7x3 on the wall? My understanding is:
a. ledger board 100mm longer than gap attached to the wall with resin and M12 x 160mm bolts
b. joist hangers attached to the ledger with square twist nails
c. new piece of 7x3 joist overlapping old joist by at least twice the total gap length (500mm in this case, that doesn't sound a lot?!), attached with m12 bolts, nuts and timber connecters at 50mm, 250mm and 450mm, zig zagged top and bottom
d. attach new joist end to joist hanger with square twist nails
Or wall pockets, we follow step C with the addition of damp proofing the ends (is this necessary in an internal wall?), cut a pocket into the brick for the joist to sit in. Is that all?
Is there a preference? Are the processes correct?
I have attached some rough floor plans of the joists and the type of connection for the sistering joists.
I read on this forum about adding a trimmer board across the ends of the joists and then just filling in the gap but wouldn't that just transfer the load of 3-4 joists onto two single ones either side?
