I was looking at getting the Einhell 4513949 Power X-Change 18V, 50Nm Cordless Combi Drill | TE-CD 18/50 Li-i 3-in-1 Brushless Drill, Impact Drill and Screwdriver, with a 4Ah battery, charger and hard case for £94 TE-CD 18/50 Li-i BL; EX, UK | Cordless Impact Drill (einhell.co.uk)
Alternatively I could get the Einhell Power X-Change 18V, 60Nm Cordless Combi Drill | TE-CD 18 Li-i 3-in-1 Brushless Drill, Impact Drill and Screwdriver, with 2 x 2.0 Ah PXC Batteries, High-Speed Charger and Storage Case for £110 TE-CD 18 Li-i BL (2x2,0Ah) | Cordless Impact Drill (einhell.co.uk)
The main reason I'm considering the latter is because it has a handle on the side and I figured that might make it easier to use and I guess 2 x 2Ah batteries is also better than one 4Ah battery because they'll be lighter. I could always buy a single 2Ah battery if I buy the drill with the 4Ah one, to have the choice between using a heavier or lighter battery depending on what I'm doing but it will cost an extra £40 and I'm not really sure there's any situation where it's better to have a heavier, bigger battery, rather than using a lighter, smaller one and switching to a second one when the first one is flat.
Is having the handle and two 2Ah batteries rather than one 4Ah the better option?
I also need to get a multi-tool, so if I get an Einhell cordless one I'd be using the same batteries with that. I'm not sure if it's worth getting a cordless one though, as the corded ones are much cheaper, like the Einhell TC-MG 220/1 E Oscillating Multi Tool | 220W Multi-Tool for £30 TC-MG 220/1 E | Multifunctional Tool (einhell.co.uk) vs the Einhell 4465160 Varrito Power X-Change Cordless Multi Tool for £72 VARRITO | Cordless Multifunctional Tool (einhell.co.uk) or the Einhell Cordless Multifunctional Tool TC-MG for £54 TC-MG 18 Li-Solo | Cordless Multifunctional Tool (einhell.co.uk) and I can imagine they're more difficult to use with the bulk and weight of a battery on the end.
I noticed that all the corded ones have "Oscillating" in the name, whilst the cordless ones don't, so I don't know if that means anything?
I also need to get a mini circular saw for cutting through floorboards (18mm) but I'm not sure if it's best to get a cordless or corded one. If I'm going to get a cordless one, I need to take that into account when deciding whether I should get the drill with the 4Ah battery or the one with the 2 x 2Ah batteries.
