All fuses at the box are in tact. Everything on the circuit this morning was working fine. TV etc all switched off when we went out and when I tried to put computer on on my return home problem became apparent. Checked surge protector on computer equipment and that is fine.
From what you say, all the appliances on one circuit (ring) are now dead. This includes TV, plug in lamps, etc.
If everything else is working i.e. ceiling lights, other ring (if you live in a house as opposed to a flat), electric cooker, etc, then this really points to the fuse area. There's not a lot else to go wrong - especially if nothing's been touched or any problems experienced.
I assume all your fuses are in a single consumer unit. I hate to say it, but check the fuse again, make sure the wire is physically connected at both ends and hasn't gone (blown) away from the centre.
Failing that, you really need to get someone in to check it. It should be very straightforward to work out the cause of the problem.
