Hi folks,
I am having a cellar conversion done, and it will of course include radiators. However even in the summer (when the central heating is switched off) the cellar is pretty cool. We will have to see whether the insulation being installed will solve this, but I suspect not - the walls don't get heated by sunlight and never will.
The conservatory on the back of the house (south-facing) gets warm, even in January, if there is decent sunlight.
I have an idea to use a centrifugal fan to suck air from high up in the conservatory and push it down through ducting and insulated hose, into a vent in the cellar wall, circulating the warm air from the conservatory into the cellar.
Possibly use one of these http://www.reuk.co.uk/buy-SOLAR-PUMP-CONTROLLER-WITH-RELAY.htm or something similar to switch the fan on only when there is a decent temperature difference.
Does anyone have any information on this sort of thing? Haven't been able to find much about it on Google, though it seems like a sound idea on the face of it. Perhaps I don't know the keywords to search for.
Total pipe run would be about 6 metres long, probably a mix of 225mm (flat) ducting (the "down" part in the conservatory) and 4" insulated pipe (for the horizontal run, which can be under the floor), of which the vertical drop would be about 2m.
Thanks in advance!
-Mark
Thanks in advance!
-Mark
